What to do with 39 H Fix or Part??
Posted by migraine on December 10, 2007 at 19:45:20 from (67.182.151.248):
Here is the dilema. Have H Farmall serial #109xx. Has Nov/Dec I(1939) codes with recessed/ notched platform,distillate carb, both tanks and all the fuel lines. Six volt and does run ok. Has a working M&W hand clutch and good brakes. The bad news is that the sheetmetal is junk form a tree falling on the gas tank and bent up grill and hood. The front tires are ok and has good 13.6-38 on back but the rims are fair at best. The rear engine and front trans seals are leaking badly and it needs a carb kit. Probably needs the head worked over and maybe new rings though it does show good oil pressure. It does smoke a little but I have not had a chance to work it hard. Is there enough value here to spend some major dollars on getting this thing suitable for public showing and use or will I spend more on it than I could ever recover? And thus should I just part it out. I realize a H is not anything special and I have 2 others. Just really don't know what to do with this thing? Thanks in advance
