Re: Clearance?
Posted by Andy Martin on December 11, 2007 at 04:28:24 from (63.99.111.179):
In Reply to: Clearance? posted by FarmallFarris on December 10, 2007 at 20:28:48:
When you use plastigage to check journal bearing clearance it definitely is total clearance.
But the guy putting 0.030 bearings on a 0.040 crank main will probably shim 0.010. Presumably he will do this on one side only and raise the crank by 0.005. I noticed lot's of folks reminding him to keep the oil hole open but if he only shims the cap he should be OK. 0.005 shouldn't affect his gear clearances appreciably.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
