Re: positive or negative ground?
Posted by Steven f/AZ on December 11, 2007 at 06:48:44 from (216.67.213.217):
In Reply to: positive or negative ground? posted by H project on December 10, 2007 at 17:03:36:
Originally positive ground, and the system will work fine if you set it up as intended.
I have run my 42 H with a magneto, 6-volt system, positive ground for over 5 years now without a problem of any sort. Haven't even adjusted the points or anything. Always starts, always runs like a top.
If your 6-volt battery isn't cranking over very well, check your connections and cables, then get a decent battery.
third party image
