Re: good news and bad news
Posted by Allan In NE on December 11, 2007 at 14:28:58 from (148.78.243.24):
In Reply to: good news and bad news posted by Nebraska Kirk on December 11, 2007 at 12:53:32:
DON'T START IT!
Get a priority valve in the circuit first or you're going to ruin that steering motor!
At the very least, it will lock the steering up tight.
You only want 3-3 1/2 gallons going to the steering. If you don't want to run a priority valve, then you must use a low volume auto-type pump run off the crankshaft pulley.
Allan
