Yep , do it all the time when more then five lits are used . Now this will add about three years to the switch . I split the system from road lites to field lites. Use a 20 amp circuit breaker with power coming off the hot post on the starter to a CV relay triggered from the work lite post off the org. lite switch to the field work lites . The problem comes from to much draw thru the power feed to the main power terminal on the lite switch and also id the org. wire end has been replaced with one of them cheep ends . If you must replace the main power feed end then get and org. Delco #56 terminal .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
