Re: Distillate A?
Posted by JT on December 12, 2007 at 18:22:16 from (70.12.249.35):
In Reply to: Distillate A? posted by tennhillbilly on December 12, 2007 at 17:15:08:
The compression sounds pretty good to me. Sounds more like you might need a good tune up, points, condensor, plugs, cap, rotor, wires, etc. The tractor is 60 years old probably needs a little attention.
