Re: Distillate A?
Posted by gene bender on December 12, 2007 at 18:50:26 from (67.55.226.214):
In Reply to: Distillate A? posted by tennhillbilly on December 12, 2007 at 17:15:08:
The dished out pistons are for the distillate fuel so your compression was ok for that engine. Like other post says mite be ok to put new rings in at this time.
