Re: 460 wide front axle
Posted by Steven f/AZ on December 14, 2007 at 11:19:39 from (216.67.213.217):
In Reply to: 460 wide front axle posted by Farm'em all on December 14, 2007 at 08:25:28:
Will it bolt up with no modifications? No.
Can it be made to fit with a little creativity and fabrication? Yes.
The 4-bolts that hold the main casting of the front end to the tractor have the same spacing from the H thru 1256 for sure (I've measured)... however, the steering arm will need to modified, along with the rear mounts/stay rod support for the front end.
It can be done, but the front of your tractor might be kinda high...
