Re: Farmall A or Super A?
Posted by Nat 2 on December 14, 2007 at 13:31:13 from (64.80.108.52):
In Reply to: How does one determine the difference between a Farmall A S posted by georgeky on December 14, 2007 at 12:57:17:
The most obvious difference is that a Super A will have a hydraulic block under the gas tank.
Serial numbers for an A are 501-250000
Serial numbers for a Super A are 250001 and higher.
You have a very early Farmall A if that serial number is is not partially worn off. 1451J means that it is serial number 1451 (the 1040th Farmall A or B made), and the J means it has a Rockford clutch.
1575 is the rated engine RPM.
