Re: How does one determine the difference between a Farmall
Posted by georgeky on December 14, 2007 at 15:05:50 from (205.188.116.73):
In Reply to: How does one determine the difference between a Farmall A S posted by arnettbros on December 14, 2007 at 12:57:17:
Mike is right, you either have a 100 or newer. Could be that it has had a newer bell housing put on. Check the engine number to see what it has on it. The 1575 is rated engine speed. If it is a 100 it will have A casting codes with that serial number. The codes will look like this and be on all major castings.Engine block, bell housing, etc. 6*21*A Looks like a smal tag with screws between the numbers and letters. The J means it has the Rockford clutch and has nothing to do with year model.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
