Re: Ih 340 utility tractor clutch release bearing
Posted by jimmY Minnesota on December 14, 2007 at 15:27:46 from (66.103.165.20):
In Reply to: Re: Ih 340 utility tractor clutch release bearing posted by RustyFarmall on December 14, 2007 at 11:01:22:
yes tractor is split, the shaft rod that goes through the clutch housing and connects to clutch bearing fork assembly inside the housing , question is how do i remove clutch rod through housing, in order to drop out bearing , the clutch rod has no retainer clips or pins to remove.
thanks jim
