Loosen the oil pressure connector at the engine. If you start it briefly and oil comes out of the fitting from pressure, then AndrewZ may be perfectly correct. If none comes out within about 15 seconds, I would probably pull the oil pan and check the pump and drive gear. There are many posts on oil pump repair in the "search for" archives above. If it does send oil out the fitting when it is loose, retighten it and use a hair dryer on the tube to the gauge. Loosen the fitting at the gauge and run the engine when it is it is warm, the moisture will be pushed out. Re tighten and see if it makes pressure. If not, try a good known gauge at the block fitting to assure your pressure. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
