Re: I've just about had it with leaks
Posted by Nebraska Cowman on December 17, 2007 at 10:41:53 from (65.162.146.41):
In Reply to: Re: I've just about had it with leaks posted by Carden on December 17, 2007 at 10:26:47:
How bad is it leaking? oil is cheap. Put a pan under it if you don't want spots on the ground. Now the brake seal you might need to fix for the brakes to work realy well. That's up to you. Some brakes run in oil all the time.
