Re: size round bale 574 can lift
Posted by georgeky on December 19, 2007 at 06:56:46 from (205.188.116.73):
In Reply to: size round bale 574 can lift posted by Yellott Canby on December 19, 2007 at 03:52:28:
Something is wrong with your 656. It will snatch any bale up when in good shape. Sounds like it needs a pump. The 574 will also lift any bale, but will need weights on the front end. The 74/84 series tractors have a very good lift. I think the 574 and 584 are rated about 4000 pounds on the lift I would get the 656 checked out. A new pump for the lift is around 400 bucks.
