Re: 1939 H FARMALL?
Posted by 39 AND HOLDEN on December 19, 2007 at 17:53:42 from (12.192.31.234):
In Reply to: 1939 H FARMALL? posted by 39 AND HOLDEN on December 18, 2007 at 20:26:39:
The serial number is FBH 1327 that would make it the 827 built I think?
The word SPECIAL is about 3" long with 1/2" tall letters with rivet headed looking things cast into the begining and end of the word.
The case # is 8276-D with a 8-24-I heat date.
Hope this helps ID it.
