Re: Super A Charging, needs flash every time I use it
Posted by Bob on December 19, 2007 at 20:08:32 from (69.178.229.154):
In Reply to: Re: Super A Charging, needs flash every time I use it posted by Janicholson on December 19, 2007 at 19:44:36:
After it has sat for enough time that you don't expect it will charge, connect a test lead from the generator's "F" terminal to a GOOD ground.
Start it up. If it charges, suspect the VR.
If it does NOT charge, check the voltage at the "A" terminal. If it's less than about 8 Volts, the cutout (in the VR) cannot be expected to pull in.
If this is the case, suspect a short in the armature, or bad field coils, or field poleshoes that have been removed, and are not TIGHTLY fastened inside the generator's "belly", or have dirt, rust, or debris clamped between them and the generator's "belly".
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
