CWB, on 6 volt systems I recomemend the biggest heaviest highest rated battery that physically fits in the mount and nuttin less then 0 better yet 00 gauge cables as mentioned below. A shop can give the battery a load test at no charge usually. If the ground is to any thin wimpy rusted sheet metal try it to a good frame bolt. Another place a problem can develop is a starter switch or solenoid. Depending on what type it is on some you can by pass jump around them n see if she cranks better then indicating a burned/carboned/resistive switch or solenoid. On tractors with the saddle mount push starter switches they can be removed and you may find the starter post is badly burned n pitted or the switch contatcs are burned/carboned/resistive.
I suggest to be safe to remove n clean n wire brush each n every battery n starter n ground n switch conenction,,,,,,,have the battery load tested n her fully charged,,,,,,,,all clean cables n conenctions n grounds,,,,,,,,big heavy battery with 00 gauge cables,,,,,,switch or solenoid test,,,,,,,,,, n then if shes till a slow cranker I suspect a starter problem like bushings or armature or a brush problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
