Re: 560 snow plow frame
Posted by Wardner on December 20, 2007 at 20:20:38 from (4.154.243.200):
In Reply to: 560 snow plow frame posted by SamC-VT on December 20, 2007 at 19:15:27:
third party image
third party image
third party image
third party image
third party image
This is a 660. The plow is an older Fisher formerly used on my F-350. I used the Fisher pump and valves as well.
I swung the 660 drawbar around similar to a Cub pulling land plows or running a grader blade. Four bolts (two would be adequate) attach the front of frame to bolster. Two bolts attach the frame to the inverted drawbar. If you want your frame to attach to the axles. you will have to use a M or H (or later) drawbar if your 560 is a Farmall. If it is an International, just do as I did.
I have more pics.
