Re: 560 snow plow frame
Posted by Hugh MacKay on December 21, 2007 at 02:53:08 from (216.208.58.132):
In Reply to: 560 snow plow frame posted by SamC-VT on December 20, 2007 at 19:15:27:
Sam: I like Wardner's idea, however if it were me and if the 560 is a Farmall, I'd run those push beams right to the rear axle housings. have them butt against axle housing by means of 3/4" plate that lies flat against axle housing, large enough so it extends above and below axle housing. Then all you need is a matching plate on back side with long 5/8" bolts clamping plates to axle housing. I say this as that is exactly how IH clamped the 2000 loader to the rear axle housing.
I realize Wardner couldn't do it that way. he has some other items in his way. I like his front end mounting, go with that 100%. Just don't clamp any part of your blade to front axle.
