I bought a 240U last Spring, and my power steering is leaking also. There is a good description of the rebuilding procedure in the I&T Manual. I bought the seals but haven"t taken it apart yet. I had no problem removing the steering linkage U-joints, but you also have to remove the dash to get the power steering out to work on. Here"s a blowup . . . basically there are two seals and an Oring. Got them thru IH
3= #355965 19= #364108 23= #374527
Mine also had a bad miss. A compression check showed zero on one cylinder, and found a few bent pushrods and a frozen exhause valve. Sent the head out. Hope yours is something else.
Good luck. Would appreciate hearing back how the power steering rebuild goes . . . will be my first job in Spring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
