Re: F-20 front and rear engine seals
Posted by Grabatire on December 21, 2007 at 17:41:04 from (216.95.83.226):
In Reply to: F-20 front and rear engine seals posted by Scott Rukke on December 20, 2007 at 20:06:48:
If the rear seal is felt, it may well be the surface of the crank on which the seal runs has a reverse groove in it. This groove is to wipe the felt as the engine rotates and bring whatever oil is oozing past, back into the crankcase. Installing a neoprene seal on this surface will cause the lip of the seal to be climbing in and out of the groove resulting in poor oil control becuse the lip may not seat itself.
I had this experience with a WD9 engine. I installed a felt seal and no more leak.
