Re: Farmall H snowplow ''floats''
Posted by Janicholson on December 21, 2007 at 18:08:44 from (66.173.50.78):
In Reply to: Farmall H snowplow ''floats'' posted by Guyzoo on December 21, 2007 at 17:41:59:
As much depends on the cutting edge of the blade where it touches 9or rides up on) the snow. If it is straight up and down, it will probably ride up. If it is dull, more than 1/2" on the wear surface, it will ride up. If the angle is good, and the mounting (push) point is at about the same elevation, it may need more weight. Tough packed snow is hard to get into with the edge. JimN
