Re: Need dimensions / SH
Posted by Gauger on December 21, 2007 at 18:47:39 from (4.252.158.73):
In Reply to: Re: Need dimensions / SH posted by pat in wis on December 21, 2007 at 14:13:31:
Hi Pat, I feel bad about not stopping by during the fall hunting season. I had the best intentions a few times but you know how that goes. The part I need is the "U" shaped bracket that is held to the light bar with a light clamp and a 1/4" capscrew. The hydraulic lever passes through the "U" and it has a roll pin in it where the rod hooks when in the back position. It has a flat spring that is held by another one of the roll pins that exerts pressure on the rod. I need material thickness, length, width and hole locations, Thanks for your help. Geoff
