Re: need help with yr and model of Farmall Super M
Posted by Janicholson on December 22, 2007 at 06:18:34 from (66.173.50.41):
In Reply to: Re: need help with yr and model of Farmall Super M posted by Armand Tatro on December 21, 2007 at 20:17:52:
Armand, with respect, it is not advisable to move a TA lever forward slowly. The lever should move as rapidly as possible without being allowed to spring on its own. The transition from Reduction to Direct and Direct to Reduction is done fast. Three primary causes of premature TA rear are Slow lever movement either direction, Moving the tractor faster than the gear it is in with the TA back, and poor adjustment. A fourth cause is not using it (they thrive on continuous use under tough conditions. JimN
