Posted by Janicholson on December 23, 2007 at 11:59:52 from (66.173.50.115):
In Reply to: Polarity of a Generator posted by Friend of the farm on December 23, 2007 at 11:10:51:
With the tractor not running, and the battery charged and hooked up, Use a 10" length of solid copper house wire with the ends stripped 1/2". Use the wire to jump between the regulator Bat or B terminal, and the Gen or Arm terminal. This will spark a little. That is it.
The field wire must be hooked up to the reg, and the reg must be grounded (as it should be. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
