Posted by John T on December 23, 2007 at 12:02:57 from (66.244.83.147):
In Reply to: Polarity of a Generator posted by Friend of the farm on December 23, 2007 at 11:10:51:
Assuming she all wired up correct BEFORE you start it momentarily use a lil wire jumper etc. to flash/jump from the Voltage Regulators BAT terminal over to its ARM/GEN terminal n you oughta get a lil spark.
If the VR's ARM/GEN terminal is hard to get at without accidentally shorting out, jump a wire from the VR BAT terminal direct to the Gennys ARM post.
On tractors with a 2 wire Cutout relay versus a 3 or 4 terminal VR, same thing basically, jump BAT terminal over to ARM/GEN or else the gennys ARM post itself.
If you cant easily get to a VR or Cutout relay, jump any hot ungrounded battery wire (like say on a starter switch/solenoid input) direct to the Gennsy ARM post n get the spark.
I sometimes say to first dead ground the gennys FLD post but thats usually NOT necessary.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
