Re: w-6 or w-9 diesel
Posted by Janicholson on December 23, 2007 at 14:45:24 from (66.173.50.175):
In Reply to: w-6 or w-9 diesel posted by JOE-ILLINOIS on December 23, 2007 at 14:10:22:
The gas start Diesel run engines are reliable if treated to cool down and shutoff procedures that keep the heads from cracking. They are pretty efficient, and do well. Most are at the same power point as the Gas engine in the same tractor, or just a bit under) if not twisted up any. They use 1/3 less fuel compared to gasoline. Parts can be purchased, they are not cheap. Good running tractors will keep doing so if treated well. They have a bit less flexibility than a Farmall in the same engine class, unless power steering they can be a bear. The seating position is either great and fits well, or is hated. The WD9 is a serious tractor and is designed for heavy drawbar tillage apps. The 6 a bit less, but in that same purpose category. I hope this helps, They seem to have values at 75 to 80% of the same size Farmall. JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
