Brake
Posted by F150Mustang on December 25, 2007 at 13:48:30 from (71.214.131.31):
Im trying to remove the rt brake cover from a 49 M, Is there a trick to this?? It seems to be hung up on the small shaft that goes thru the cover. I have everything off and with a pry bar got it to move about a eigth of an inch. Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
