Re: Brake
Posted by riverbend on December 26, 2007 at 06:25:03 from (208.160.33.41):
In Reply to: Brake posted by F150Mustang on December 25, 2007 at 13:48:30:
Usually you take the cover off with the arm, shaft, brake band, etc. as an assembly. If you have taken the band lever arm off, try putting it back on, working it back and forth as you pull on it like a handle. As you turn it counterclockwise, it releases the band.
Greg
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
