Re: Farmall M Starter Rebuild - Any Tips?
Posted by CNKS on December 25, 2007 at 16:46:56 from (216.144.104.128):
In Reply to: Farmall M Starter Rebuild - Any Tips? posted by Clarkbug on December 25, 2007 at 16:39:39:
You can fix it yourself, but I prefer to take starters and generators to a repair shop for anything more than replacing brushes. They have the parts, and will only charge an hours labor or so.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
