napa will prolly have or be able to get everything you need. there is a new style bendix available for that starter, you may have to get that from case i-h. while your in there check the bushings on either end of the starter. when they get wore, it makes the starter draw a lot more amps .napa can get em hey are pretty easy to change. the one in the nose you can drive right out. the one on the back side is a little trickier to get out. i used a pilot bearing puller to get mine out. you could always go in with a small punch or chisel and fold it in a little to grip it with vice grips and pull it out.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
