Re: Leaking carb Help
Posted by Andy Martin on December 26, 2007 at 05:43:47 from (63.99.111.188):
In Reply to: Leaking carb Help posted by Dave Ulm on December 26, 2007 at 05:29:39:
First take it apart and clean it out. It probably just has a bit of trash under the needle valve and does not need a new one.
If you tear up the gasket, put it back in best you can. They only seal against sloshing fuel and I've used a broken one many times.
