Re: Farmall M Starter Rebuild - Any Tips?
Posted by Bill in IL on December 26, 2007 at 09:04:02 from (131.43.10.190):
In Reply to: Farmall M Starter Rebuild - Any Tips? posted by Clarkbug on December 25, 2007 at 16:39:39:
I had the same problem with a starter on an 880 oliver. (Sorry to mix green in the red forum) I had the local auto parts store cross reference the starter case number (windings and brushes) with their book and turned out a delco starter for a car had the same motor with a different drive so to save time in the rebuild shop (was told a week minimum) I swapped the outer case and its been working great. Only cost about 35 bucks too. If the rest of your starter is good you maybe can do the same thing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
