The electrical system is a positive ground. The cable that is attached to the positive post of the battery will most likely be attached to the chassis with one of the same bolts that is used to attach the starter to the tractor. This is the ground. The cable that is attached to the battery negative post is attached at its other end to one side of the starter button, and the opposite side of the starter button has a cable from it to the post on the starter. Click on the link for a better explanation.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
