Re: Hydraulic TA freewheeling down hills
Posted by Kevin Meier on December 26, 2007 at 13:40:47 from (64.71.85.247):
In Reply to: Hydraulic TA freewheeling down hills posted by Nat 2 on December 26, 2007 at 12:21:45:
FREEWHEELING ON LOW SIDE OF TA. A. SELECTOR SPOOL NOT PROPERLY ADJUSTED.
A. ADJUST SELECTOR SPOOL TO SPECIFICATION (YOU MUST OBTAIN 1 1/8" UP TRAVEL FIRST.
B. 86 SERIES SELECTOR SPOOL CABLE STRETCHED OR BROKEN. B. REPLACE WITH NEW CABLE AND ADJUST TO CORRECT SPECIFICATION (1 1/8" UP TRAVEL FIRST).
C. DUMP VALVE IMPROPERLY ADJUSTED. C. ADJUST DUMP VALVE TO CORRECT SPECIFICATION.
D. LOW CLUTCH PRESSURE. D. INCREASE PRESSURE BY REPLACING REGULATOR SPRINGS.
E. TRACTOR OVER BALLASTED. (FLUID IN TIRES, TOO MANY WEIGHTS ON TRACTOR. E. REMOVE FLUID AND WEIGHTS FROM TRACTOR (IF TRACTOR STILL FREEWHEELS, CALL AG PARTS FOR SUPER TA REPLACEMENT).
