Re: Super H Sediment Bowl
Posted by Allan In NE on December 26, 2007 at 16:43:45 from (148.78.243.24):
In Reply to: Super H Sediment Bowl posted by MN Scott on December 26, 2007 at 16:21:31:
That "Only a few drips in the bowl" happens every time ya have the bowl off.
Choke it and fire it up; it will purge the trapped air all on it's own.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
