Re: Super H Sediment Bowl
Posted by Steven f/AZ on December 26, 2007 at 18:43:43 from (24.121.155.84):
In Reply to: Super H Sediment Bowl posted by MN Scott on December 26, 2007 at 16:21:31:
Are you sure there is enough fuel in the tank? Mine sticks up into the tank a little bit so the crud at the bottom can't get into the sediment bowl... takes a couple gallons to get it up over that. Just a thought to check on.
