Re: IH 1486 questions
Posted by Sheepdog in NE on December 26, 2007 at 19:36:19 from (204.77.166.193):
In Reply to: IH 1486 questions posted by nates90 on December 26, 2007 at 08:49:48:
The lite that comes on when you step in the clutch is normal. If it comes on when your driving the tractor (clutch pedal back)then you have low PSI. The brake lite coming on means the your brake discs need replacing. The TA lever can be used in any position. If you need more power to pull a load easier pull it back. When you get over the load push it forward. The dif-lock has a button you push with the heel of your foot on the floor boards. No button no dif-lock. Hope this helps. Happy New Year!
