Re: 966 that smokes
Posted by Owen Aaland on December 27, 2007 at 11:03:25 from (65.165.246.41):
In Reply to: 966 that smokes posted by O6'er on December 27, 2007 at 08:12:19:
What happens to the injectors when they get a lot of hours on them is the opening pressure drops off. As the pressure drops they do not do as good a job of atomizing the fuel. That leads to more smoke and less power.
The down side of getting the pressure back where it should be is, if you have a weak pump you may find the the engine will be harder to start because the pump has to work harder to open the injectors.
