Re: 87 or 92 Octane Gas
Posted by John T on December 28, 2007 at 05:35:14 from (66.244.83.147):
In Reply to: 87 or 92 Octane Gas posted by Minnesotan H on December 27, 2007 at 19:49:50:
Minn H, UNLESS the tractor has very high compression to the point high octane fuel is required to prevent pre ignition n spark knock I SEE NO REASON OR BENEFIT TO BE GAINED FROM HIGHER OCTANE GAS THEN NECESSARY.... In fact it may even be detrimental in my opinion. Higher octane gas is necessarily by design n formualtion HARDER TO IGNITE n has a certain controlled burn rate n Id rather do a good job of igniting n completely burning the fuel versus it being left as unspent residue n maybe more carbon deposits....
NOWWWWWW if she has high compression you need that high octane gas and can gain improvement with more compression n resulting HP PROVIDED you burn the higher octane fuel so she isnt pre igniting........
Sooooooo "Thats my story n Ima stickin to it" lol
Take care yall
John T
