"that use of the necesary higher octane in a higher compression engine is, of course, an advantage buttttttttt use of higher octane then necessary in a lower compression engine can even be detrimental"
Agreed.
The only way to take advantage of the power POTENTIAL of high octane is to have a high compression engine (8.8:1 compression ratio or higher) in a vacuum advance inginition system. However, even that is debateable in modern vehicles.
My 3.0 Duratech engine has a 10:1 compression ratio with electronic controlled ignition. I have noticed no differance in mileage or power when using the 91 octane instead of Ford's recomended 87 octane.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
