Posted by r4etired on December 28, 2007 at 16:03:52 from (166.225.64.121):
In Reply to: Farmall M 9 Speed posted by Bill in IL on December 28, 2007 at 12:22:51:
The shift lever is at the bottom of the transmission.one end,the operating end attaches to the shift arm,the shift mechanism is directly under the bottom trans shaft, the other end attaches to a replacement pin that holds the short reverse shaft.Moving the shift arm moves the pins that slide the drive dog that is either in high,neutral or low.This is the way MandW works.I can't tell you about the Heisler or the Behlen as around here everyone used MW,
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
