Re: Super A Rock Shaft Lift Link
Posted by CityBoy-McCoy on December 28, 2007 at 16:50:31 from (209.214.107.66):
In Reply to: Super A Rock Shaft Lift Link posted by SuperA-Tx on December 28, 2007 at 13:54:07:
For about two years I owned two 1953 Super A's, both in the 346,000 serial number range. 346977 had a spring on the rear lift arm; 346498 did not. I did not give it a lot of thought - just assumed the one without had "lost" its spring over the years. I still have that tractor. mike
