Posted by Fromjb2 on December 29, 2007 at 05:47:48 from (99.241.179.24):
In Reply to: B275 stops running posted by Daniel Hindry on December 28, 2007 at 23:53:17:
Hi Daniel, have experienced a similar problem on a B414D which is same as B275 expect B414D has BD154 engine. Our problem was caused by junk in the bottom of the fuel tank. Try a simple thing first, try running it with the fuel tank filler cap removed just in case the vent holes are clogged. If it stops after 20 minutes then with a clean container to catch the fuel, open the fuel supply line at the right side of the tractor there should be a fuel shut off valve between the tank and the lift pump. The fuel should flow the full of the pipe from the fuel tank. If it doesnt then the problem is between there and the tank. Hugh also had some good suggestions about fuel line leaks.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
