B-275 starting after lay up
Posted by gerardt on December 29, 2007 at 11:06:04 from (81.151.43.134):
Hi. I"ve been given a b-275 which has not been used for 5 years. Before I replace all the electrics (they"ve been eaten by something) I want to find out if the engine will turn. Can anyone tell me how to crank it by hand please?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
