Re: B275 stops running
Posted by Daniel Hindry on December 29, 2007 at 17:31:59 from (203.97.108.140):
In Reply to: B275 stops running posted by Daniel Hindry on December 28, 2007 at 23:53:17:
Thanks for all your suggestions guys. I have been through and checked/tightened all the fuel lines. I have checked for blockages from the fuel tank too. Everything seems tight and their is tons of fuel feeding from the small fuel pump over to the fuel filter.
I have bled the system again and it has started first time. I also took the oil filled air filter off and replaced the oil in this.
I have taken some photos to see if the fuel injector pump can be identified. It is fed via to fuel lines from the canister fuel filter. It also has a pipe that comes down from the exhaust manifold and goes into the front of the case where I assume the drive cog is.
Here are the photos....
Http://hindry.net.nz/photography/tractor/sm0003.JPG
Http://hindry.net.nz/photography/tractor/sm0002.JPG
Http://hindry.net.nz/photography/tractor/sm0001.JPG
Thanks
Daniel
