In the old days we used straight 30W in summer and straight 10W in winter here in Wisconsin. I use 10w30 diesel oil (detergent) now.Works fine for me-others surely will have different thoughts.The governor does not have seperate lubrication,it`s lubed by the crankcase oil. Depending which PTO you have: 2qt. 10W oil for planetary type, 1 pt. Hy Tran for clutch type.
You check the transmission fluid level by unscrewing a cap screw on the left side of trans. case below the footrest and somewhat hidden by the clutch pedal.You are correct in using Hy Tran in it. There is a filter on the right side of tractor -kind of a square plate down low by brake pedals.As far as serial # tag - it`s on the right side on cluth housing right next to the oil filter housing on the engine.It is a metal tag riveted to the housing. Hope this helps, Mark
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
