400 RC brake
Posted by Paul in WI on December 30, 2007 at 13:59:17 from (67.54.132.177):
Can the shaft that supports the clutch and runs the left brake and pass' thru to the peddle on the right side be removed without a major take apart?
I need to build up the shaft at the clutch peddle due to wear, so that the peddle will not move side to side.
What have you all done to fix this problem?
