Re: 400 RC brake
Posted by SDE on December 30, 2007 at 15:56:03 from (69.179.2.124):
In Reply to: 400 RC brake posted by Paul in WI on December 30, 2007 at 13:59:17:
I have removed the shafts on both of my 400s. You will need to remove both of the brake pedals and the clutch pedal also. After removing the woodruff keys it will slide out easily enough. I don't remember if it even matters which side it slides out.
Weld it up.
Turn it down.
Slide back in.
I turned mine at work myself.
Pretty easy job.
SDE
