Re: Farmall C manifold
Posted by RustyFarmall on December 31, 2007 at 07:25:30 from (209.152.78.71):
In Reply to: Farmall C manifold posted by Greg 2010 on December 31, 2007 at 07:12:06:
Yes, that pipe will screw out, but it probably will not be that easy because it will be rusted in there pretty good. You might want to try sawing it off flush with top of the manifold, and then use a hack saw blade to split what is still inside, and then sort of peel it out. It will take a bit of doing, but you can do it.
